Kit TLR 3.0 + peças
9 mensagens
- PhBuggy
- Registrado em: 30 Out 2011, 21:00
Kit TLR 3.0 + peças
1 TLR04000 Kit TLR 3.0 completo (usado / sem motor / sem servo);
1 TLR99059 Caixa de partida da TLR (usada);
1 PTK-LP-2100-4S20 Bateria da ProTek R/C 4S Li-Poly 20C Battery Pack (14.8V/2100mAh) (Starter Box) de 4S para a cx de partida (usada);
2 PTK-LP-RX2000-S-2S - Baterias da ProTek R/C Li-Poly Losi 8ight Receiver Battery Pack (7.4V/2000mAh) (w/Balancer Plug) para o carro (usada);
1 TLR244021 - Team Losi Racing 8IGHT Aluminum Servo Saver Top (usado) - up grade;
1 LOSA4440 - Losi 8IGHT Aluminum Front Top Brace (usado) - up grade;
1 PTK-7805 - ProTek R/C Aluminum Servo Horn (25T-Futaba/Orion/Savox/ProTek) (seminovo) - up grade;
1 TLR1557 - Team Losi Racing Aluminum Servo Horn (25T-Futaba/Orion/Savox/ACE) (TLR 22) (seminovo) - up grade;
1 LOSA4417 - Losi Aluminum Rear Chassis Brace (seminova) - up grade;
1 TLR3510 - Team Losi Racing Front Overdrive Gear Set (8B) (seminova) - up grade;
1 LNS7380 - Lunsford "Quick Tune" Losi 8ight/8T Titanium Shock Mounts (4) (seminova) - up grade;
1 LOSB5011 - Losi Fuel Tank Lid Pull Set (Fluorescent Yellow) (2) (seminova) - up grade;
1 LOSA9155 - Losi Quick Change Engine Mount Set (seminova) - up grade;
1 LOSA4444 - Losi Aluminum Split Center Differential Mount (seminova) - up grade;
1 LOSA1732 - Losi Aluminum Rear Hub Carriers (2.0) (seminova) - up grade;
1 RBD02013-007 - RB Products "A.D.S." Automatic Damping System Set (Losi 8IGHT 3.0) (seminova) - up grade.
Peças novas (zerada):
3 TLR244011 - Team Losi Racing 4x66mm TiCn Inner Hinge Pin (2);
4 TLR242003 - Team Losi Racing Coupler Outdrive;
2 TLR244000 - Team Losi Racing Front Suspension Arm Set;
1 TLR244008 - Team Losi Racing Rear Suspension Arm Set;
2 TLR342000 - Team Losi Racing Rear Dogbone (2) (Traseiro - 8B 3.0);
1 TLR240001 - Team Losi Racing 8IGHT 3.0 Wing (Black);
1 TLR243007 - Team Losi Racing 4x54mm TiCn Front Shock Shaft;
1 TLR4401 - Team Losi Racing "Gen III" Radio Tray;
1 TLR243008 - Team Losi Racing 4x59.5mm TiCn Rear Shock Shaft;
2 TLR340001 - Team Losi Racing 8IGHT 3.0 Cab Forward Body (Clear);1 LOSA 4435 - Losi Wing Mount Set - 2;
1 TLR243019 - Team Losi Racing Rear 16mm Shock Spring Set (Silver -3.6 Rate);
1 TLR3538 - Team Losi Racing Aluminum Covered 17mm Wheel Nuts (Hard Anodized) (4);
1 TLR240001 - Wing, Black 8IGHT Buggy 3.0;
1 TLR243002 - 16mm Shock Body Set, Front (2);
1 TLR243003 - Team Losi Racing 16mm Rear Shock Body (2);
1 TLR243018 - Team Losi Racing 16mm Rear Shock Spring Set (Red - 3.4 Rate) (2);
1 TLR243016 - Team Losi Racing 16mm Front Shock Spring Set (Green - 4.8 Rate) (2);
1 TLR243019 - Team Losi Racing Rear 16mm Shock Spring Set (Silver -3.6 Rate) (2);
1 LOSA1756 - Losi Adjustable Hinge Pin Brace Insert Set;
1 LOSA 9125 - Losi 12T High Endurance Clutch Bell;
1 LOSA6046 - Losi 4mm Rod End Set;
1 LOSA6056 - Losi 6.8mm Suspension Balls (4);
1 LOSA3501 - Losi 6x11x.2mm Differential Shims;
2 LOSA6306 - Losi 4-40 Aluminum Mini Nuts (10);
1 Team Losi Racing 8IGHT 2.0 Cab Forward Body EU (Clear);
1 LOSA9106 - Losi 4 Shoe Clutch Pin & Hardware Set ;
1 LOSA4420 - Losi Center Differential Mount & Brace Set;
1 LOSA3510 - Losi Rear Differential Ring Gear;
1 LOSA1731 - Losi Rear Hub Carriers;
1 LOSA99424 - Losi Starter Drive Belt;
1 LOSA99421 - Losi Starter Wheel;
1 LOSA9102 - Losi 4 Shoe Steel Flywheel & Collet (8IGHT/8IGHT-T);
1 LOSA9105 - Losi Aluminum 4 Shoe Flywheel & Collet Set (8IGHT);
1 LOSA 6287 - Losi 4-40 x 1 1/4 Cap Head Screws (6);
1 LOSA6050 - Losi 6.8mm Steering Ball Set;
1 LOSA6227 - Losi 4-40x1/8” Hardened Set Screws;
1 LOSA6249 - Losi 4-40x0.150" Flat Head Screw (10);
1 LOSA6384 - Losi 5-40x20mm Left Hand Thread Button Head Screw (10);
2 LOSA4435 - Losi Wing Mount Set;
2 DER 110-10 DE Racing Mud Guard Set (TEN-T/SCTE/810);
2 CRP 0011 Competition Suspension Losi 8IGHT EX Performance Shock O-Rings (8);
2 LOSA9162 - Losi Fuel Tank (8IGHT 2.0) ;
1 LOSA4446 - Losi Steering Bellcrank & Servo Saver Set;
1 LOSA4413 - Losi Front Chassis Brace Set;
1 LOSA4408 - Losi Steering Post Set;
1 LOSA3556 - Losi 48T Lightweight Center Differential Spur Gear;
1 LOSA3505 - Differential Seal Set: 8B,8T, LST, XXL, MB;
2 LOSA9108 - Losi Aluminum Clutch Shoes (2);
1 LOSA3532 - Losi Wheel Hexes + 2mm Wider (4) (8IGHT/8IGHT-T);
1 LOSA9113 - Losi 036” 30 Deg Clutch Springs (Green);
1 LOSA 9114 - Losi 040” 25 Degree Clutch Springs (Gold);
1 LOSA9112 - Losi .036” 25 Degree Clutch Springs (Black);
1 LOSA5438 - Losi Shock Standoff (1);
1 LOSA9154 - Losi Engine Mount Set;
1 LOSA3522 - Losi F/R CV Driveshaft Axles (1)
2 jogos de rolamento completo;
1 cx de parafuso completa;
1 Diff central completo + freio + Mount & Brace Set + Filter Guard;
Peças Usadas:
Tenho muita coisa.... molas preta / verde / cinza dos amortecedores, chassis da BCE, sapatas (alumínio e carbono), parafusos, porcas, dogbone, 1 frente completa (sem torre), 1 central completa, 1 traseira completa (sem torre); rolamentos, flywhweel de alumínio e de ferro, sino de 13T, 14T e 12T, coroa central de 45T / 46T / 48T, Losi Front Center Universal Driveshaft, Losi Drive Pin Set, Losi 6x11x.2mm Differential Shims, Team Losi Racing Aluminum Differential Shaft Set (6)
Ferramentas (usadas)
1 TLR99102 - Turnbuckle Wrench;
1 LOSA99172 - Losi Camber Gauge;
1 TLR99101 - Shock Shaft Pliers;
1 LOSA99150 - Losi 4 Piece Race Nut Driver Set (US Sizes);
1 LOSA 99104 - Losi Race Wrench: US 4 pc Set.
Sou de Campinas e frequento a pista de Paulinia / Dust / Rio Claro!
Peças Usadas:
Nenhuma proposta em andamento.
Raphael Oliveira - PH
Campinas / SP
Tel. e ZapZap (19) 99211-7059
Campinas / SP
Mugen OS M12S Byron Mion Bolhas PL Paulinia Racing |
- PhBuggy
Kit TLR 3.0 + peças
OPORTUNIDADE!
VALOR TOTAL R$ 3.500,00
INFELIZMENTE NÃO ACEITO TROCAS!
OBRIGADO E ESTOU À DISPOSIÇÃO.
Campinas / SP
Campinas / SP
- R.Caike
- Registrado em: 19 Jun 2013, 23:00
Re: Kit TLR 3.0 + peças
quanto pede só no chassis?
Mugen MBX7R O.S XZ-B / Orion Sanwa M11 VP Aka/Proline/Sweep |
- davidgirdan
- Registrado em: 16 Jul 2009, 23:00
fotos para david.silva777@gmail.com
RC8T / RC8.2 Reds / keeps off futaba 4pks byron fuel pro G2 / odonnel proline/ jconcets sweep Tires/ pro circuit AABB / GUTO |
- R.Caike
me manda foto do chassi, meu e mail é caike_moreira@hotmail.com
- PhBuggy
Campinas / SP
Campinas / SP
- PhBuggy
Campinas / SP
Campinas / SP
- R.Caike
confere o e-mail pra gente fechar
- PhBuggy
Enviado!
R.Caike escreveu:confere o e-mail pra gente fechar
Campinas / SP
Campinas / SP
9 mensagens
Voltar para FR - Carros Off Road
Usuários navegando neste fórum: Nenhum usuário registrado e 16 visitantes
