[VENDO] Motor Axial .32 rr-1 - NOVO - BARATO
17 mensagens
• Página 1 de 2 • 1, 2
- caobianco
- Registrado em: 05 Mai 2009, 23:00
Queimando,
motor Axial .32 RR -1 cabeçote preto.
Motor NOVO, na caixa, nunca ligou.
Preço : R$ 350,00
Segue dados do mesmo :
SPECS: Displacement: .32 cu in (5.2cc)
Maximum RPM: 37,500
Bore: 19.5mm
Stroke: 17.5mm
Distance Between Mounting Holes Same Side: 22mm (0.87")
Distance Between Mounting Holes Opposite Side: 37.03mm (1.45")
Height Bottom of Mounting Tabs/Top of Cylinder Head: 100.4mm (3.9")
Width at Mounting Tabs: 45mm (1.8")
Distance from Pull Starter to Front Bearing: 83.22mm (3.276")
Distance from Center of Engine to Front Bearing: 41.61mm (1.63")
Distance from Center of Engine to Pull Starter: 41.61mm (1.63")
Carburetor Settings: Factory set for proper break-in-reset only after
engine is fully broken in
High Speed Needle-Turn in 1/8 turn increments to lean out fuel
mixture to a maximum 2-1/2 turns from flush
Idle Adjustment Screw-Turn on radio and set throttle trim to
neutral, turn idle adjustment screw to set idle high enough to
keep engine running but not high enough to engage clutch
Low Speed Needle-Leave at factory setting, no adjustment needed
Preço : R$ 350,00
Maximum RPM: 37,500
Bore: 19.5mm
Stroke: 17.5mm
A Proposta (nº 364391) do usuário Fabiohj (1 pts) foi aceita! O usuário caobianco deu uma qualificação POSITIVA para o usuário Fabiohj. O usuário Fabiohj deu uma qualificação POSITIVA para o usuário caobianco.
JQ / 811T / Revo / Savage Reedy / Reedy / 3.3 / .28 M11 / Spectrum Tornado 30 / Byron 20 Punisher / Pontiac / ElCaminho Pro Line 40 / hpi Terra Pin Dust |
- caobianco
Re: [VENDO] Motor Axial .32 rr-1 - NOVO - BARATO
Foto do mesmo :
- felipeps
- Registrado em: 11 Jan 2010, 21:00
Serve no meu kyosho inferto st?
madForce/733te/losi2.0rr..... Nova btt/Picco/Team orion crf tactic 2.4/dx3s Odonel 30%/tornado 16% varias bem raladas Pro line qualquer uma |
- caobianco
felipeps escreveu:Serve no meu kyosho inferto st?
kkkk
troca o montante que serve ....rs
vc ta zoando, o meu st-us rodava com um desses ... cansei de empurrar o jorge la na don com ele nessa configuração.
- luismiro
- Registrado em: 23 Mar 2009, 22:00
Amigao, nao entendo muito de Axial, mas esse motor é RR mesmo? Estou perguntando isso pq o que eu vi era cabeçote verde. Se for RR mesmo ele me interessa.
- caobianco
luismiro escreveu:Amigao, nao entendo muito de Axial, mas esse motor é RR mesmo? Estou perguntando isso pq o que eu vi era cabeçote verde. Se for RR mesmo ele me interessa.
Luis, boa noite.
É rr mesmo. O .32 só tem rr de cabeçote preto.
Moro em sp-capital, se quiser, pode retirar o mesmo comigo sem problemas.
- luismiro
Comprei uma bateria lipo com vc, nao foi um LRP nao. rsrsrsr. mas beleza, me manda seu cel via MP que eu te ligo. valeu
- absertorio
- Registrado em: 25 Jun 2010, 23:00
ola gostaria de saber se este motor serve na savage xl se e igual ou mais forte que o 5.9 aguardo.
- caobianco
absertorio escreveu:ola gostaria de saber se este motor serve na savage xl se e igual ou mais forte que o 5.9 aguardo.
Amigo, respondendo as suas dúvidas :
1. Serve na savage XL como uma luva. (se voce quiser usar o RotoStart, terá que comprar um adaptador).
2. Eu nunca usei nenhum dos dois na minha savage, portanto fica difícil opinar. Tem um usuário do forum que já usou e esta vendendo a savage XL dele com esse motor : /viewtopic.php?t=35411
Se voce puder, fale com ele a respeito do mesmo.
Obrigado
- lukits
serve na revo??? daria pra colocar com o ez-start??
- caobianco
lukits escreveu:serve na revo??? daria pra colocar com o ez-start??
Serve, se vc colocar o montante da new era.
O Ez start paras funcionar teria que adaptar.
- lukits
hum, mas ficaria bom? pois é um motor grande e o preço esta muito bom... ficaria melhor que o trx3.3??
- caobianco
lukits escreveu:hum, mas ficaria bom? pois é um motor grande e o preço esta muito bom... ficaria melhor que o trx3.3??
Meu caro, tenho uma Revo aqui em casa, porém, nunca coloquei um motor desses nela.
Teria que testar mesmo, na Savage eu sei que fica bom.
- Fabiohj
- Registrado em: 07 Mar 2011, 22:00
Ainda a venda? Sabe se serve no Warhead e se fica bom?
Negociação:
- caobianco
Fabiohj escreveu:Ainda a venda? Sabe se serve no Warhead e se fica bom?
Esta a venda.
Não conheço o seu carro, qual o fabricante ?
17 mensagens
Voltar para FR - Motores Off Road
