RC Cheat Sheets iPhone® App
4 mensagens
Agora você pode rapidamente compreender como ajustar seus carros ON ou OFF em relação ao Setup!
[center][/center]
Within a range of tuning options, which is better, a higher number or lower? Thicker or thinner? How will a longer or shorter adjustment change the handling? If you keep scratching your head trying to remember -- RC Cheat Sheets to the rescue!
For those of us who haven't yet grasped the theory and physics of the tuning possibilities behind the many setup options, RC Cheat Sheets with its 100+ cheat sheets and 70+ full-color photos will give you shortcuts to the information you need to make changes intelligently and quickly.
This app puts valuable information at your fingertips for offroad, onroad, and oval styles, and electric and nitro vehicles. These cheat sheets -- quick-lookup mini tuning guides -- are useful for a wide range of RC brands, not just Team Associated vehicles.
Cheat Sheets cover a wide range of settings for:
* Offroad and Onroad: Ackermann, Anti-dive, Anti-roll Bars, Anti-squat, Axle Height, and more!
* Electrical: Battery "C" Rating, Battery mAh Rating, Battery Cell Count, Battery Label Reading, and more!
* Nitro: Carb Restrictor, Carb settings, Clutch Bell, and more!
* Pan Cars: Active Strut, Battery Placement (Oval), Center Damping, Center Spring, and more!
Easy-to-use calculators included in the app for:
* Gear Ratio
* Final Drive Ratio
* Roll-out
* Transmission Ratio
Convert between units of:
* Length and Distance: Eight measurements!
* Temperature: Fahrenheit and Celsius
* Weight: Grams, Ounces, Pounds, Kilograms
Tools include:
* Lap Counter (copy the information with three taps, then paste it into the iPhone's email app to export!)
* Random Number Generator (who's going first?)
At your fingertips are helpful checklists and charts:
* Maintenance Checklist
* Transmission Ratios: offroad and onroad for aí vehicles
* RC Toolbox: must-have items for electric and nitro vehicles
* Fraction Equivalents
* Drill Chart
* Frequencies
* How to Go Faster Checklist
* Common Beginner Mistakes Checklist
... all this and more ... for only $2.99!
More key features include:
* A Bookmark function helps you retrieve favorite cheat sheets quickly at the pit table.
* Search allows you to find a relevant cheat sheet quickly. Try "push," "traction," "steering," "jumps," for example.
* Rotate the device to enlarge the full-color photos.
* Adjustable font size for easier reading.
[center][youtube]http://www.youtube.com/watch?v=6LSulrMZs4c[/youtube][/center]
[center][/center]
* Gear Ratio
* Final Drive Ratio
* Roll-out
Tools include:
* Drill Chart
* Frequencies
- nbrancalhaojr
- Registrado em: 27 Set 2009, 23:00
Re: RC Cheat Sheets iPhone® App
Bacana a idéia, já testou?
Vou baixar
Vou baixar
nbrancalhaojr escreveu:Bacana a idéia, já testou?
Vou baixar
Testei e achei interessante ja que existem algumas imagens explicando o funcionamento de cada componente para um setup conforme a pista e o estilo do piloto. Existem algumas ferrementas inuteis mas isto é comum. Vale a pena conferir
http://www.redrc.net/2011/02/associated ... phone-app/
http://www.neobuggy.net/modules/news/ar ... oryid=9774
Achei muito iteressante, parece ter bastante coisas.
Mugen MBX6 Novarossi P4 Sanwa MT-4 O'Donnell (?) Bitty Sweep São Paulo |
4 mensagens
Usuários navegando neste fórum: Nenhum usuário registrado e 6 visitantes
