[VENDO] Combo Esc Hobbywing + Motor Speed Passion + Card + Bateria
11 mensagens
- LGBMOURA
- Registrado em: 09 Jun 2007, 23:00
EQUIPE SEU AUTOMODELO COM A MELHOR COMBINAÇÃO:
ESC + MOTOR + CARTÃO DE PROGRAMAÇÃO + BATERIA LIPO
COMBO EM EXCELENTE ESTADO, É SÓ INSTALAR NO CARRO E CURTIR!
ÓTIMO PARA DRIFT!
- ESC HOBBYWING 60A SENSORLESS PARA MOTORES BRUSHLESS
- MOTOR SPEED PASSION SPORT TUNED 2500Kv (13,5T) BRUSHLESS E SENSORLESS
- CARTÃO DE PROGRAMAÇÃO PARA O ESC
- BATERIA LIPO TURNIGY DE 4.000 mAh 40C HARD CASE
COM ESTE MOTOR, ESC E BATERIA VOCÊ ANDA ATÉ 20 MINUTOS SEM RECARREGAR.
ESC Specifications
- ESC Model: EZRUN-60A-SL
- Dimensions: 31.5mm x 27.5mm x 24mm (The height of fan is not included)
- Net Weight: 32g (without wires)
- Continuous Current: 60A
- Burst Current: 380A
- Resistance: 0.0007 ohm
- BEC Output: 6V/1.5A
- Suitable Brushless Motor:
- On-road: =>5.5T, Off-road: =>8.5T (2 cells Lipo / 6 cells NiMH)
- On-road: =>8.5T, Off-road: =>13T (3 cells Lipo / 9 cells NiMH)
- Working Battery Types: 4 - 9 Cells (NiMh) / 2 - 3 Cells (Li-Po)
- Motor Type: Sensorless Brushless Motor
- User Programmable: Available
- Cable Type: 14 AWG (Battery and Motor)
- Cable Length: 100mm (Motor), 150mm (Battery), 220mm (Receiver)
- Recommend Model: RC Model 1/10 Car
ESC Features
- Specially designed for RC car and truck, with excellent start-up, acceleration and linearity festures.
- Compatible with sensorless brushless motor.
- 3 running modes suitable for different applications ("Forward with brake" mode, "Forward/Backward with brake" mode and "Rock crawier" mode).
- 4 steps of maximum reverse force adjustment.
- Proportional ABS brake function with 4 steps of maximum brake force adjustment, 8 steps of drag-brake force adjustment and 4 steps of initial brake force adjustment.
- 9 start modes ("Punch") from "Soft" to "very aggressive" to be suitable for different chassis, tires and tracks.
- Multiple protection features: Low voltage cut-off protection for lithium or nickel battery / Over-heat protection / Throttle signal loss protection / Motor blocked protection.
- 8 steps of timing adjustment.
- User Programmable. Several program methods are supported, such as: The "SET" button on the ESC, the digital LED program card, the advanced LCD program box, the PC software, etc. The program card and program box are pocket-sized and they have friendly user interface to be easily used.
- Dustproof
Program Card Features
- Running Mode
- Drag Brake Force
- Low Voltage Cut-Off Threshold
- Start Mode
- Maximum Brake Force
- Maximum Reverse Force
- Initial Brake Force
- Throttle Neutral Range
- Timing
- Over-Heat Protection
- Motor Rotation
- Lipo Cells
Preço de venda: 250,00
ÓTIMO PARA DRIFT!
ESC Specifications
ESC Features
- Dustproof
- Running Mode
- Drag Brake Force
- Start Mode
- Timing
- Motor Rotation
- Lipo Cells
A Proposta (nº 442495) do usuário Galli (2 pts) foi aceita! O usuário Galli deu uma qualificação POSITIVA para o usuário LGBMOURA. O usuário LGBMOURA deu uma qualificação POSITIVA para o usuário Galli.
Obs: Qualificações Neutras normalmente significam que o negócio foi cancelado.
- hugoyh
- Registrado em: 13 Jul 2011, 23:00
Re: [VENDO] Combo Esc Hobbywing + Motor Speed Passion + Card + Bateria
Amigo quanto faz sem a bateria?
HugoYH
uma penca pra todos os gostos ixi, alguns... GP e EP Varias marcas de pacote ruas de SP |
- peter.oggi84
- Registrado em: 31 Ago 2011, 23:00
amigao este kit serve em buggy ou truggy , tamem sou de curitiba e tenho interesse no kit
piloto kbaço
inferno MP5/losi RR Mach427/ 21-4 T DX3 C o`donnel bolha original pro line / sintex amec / pista no quintal |
- LGBMOURA
hugoyh escreveu:Amigo quanto faz sem a bateria?
Não vendo separado. A bateria está nova.
- LGBMOURA
peter.oggi84 escreveu:amigao este kit serve em buggy ou truggy , tamem sou de curitiba e tenho interesse no kit
Este combo é para modelos 1/10 e 1/12. Não sei se serve em buggy e truggy. Imagino que se forem 1/10, deve servir.
- hugoyh
LGBMOURA escreveu:hugoyh escreveu:Amigo quanto faz sem a bateria?
tem como fazer 200,00 no kit?
HugoYH
- LGBMOURA
hugoyh escreveu:LGBMOURA escreveu:hugoyh escreveu:Amigo quanto faz sem a bateria?
Mandei MP.
- Galli
- Registrado em: 17 Mar 2011, 22:00
Bom dia vou fazer a transferencia agora mesmo blz?
falou!!!!!
falou!!!!!
Negociação:
Mugen .12 2.4 20/16 Audi 37 Uniso |
- Galli
Transferencia efetuada aguardo confirmacao e envio.
falou!!!!
falou!!!!
11 mensagens
Voltar para FR - Motores Elétricos
