[VENDO] HPI 1/5 Baja 5B Buggy RTR
Carros e Chassis Off Road.
rodrigofelippe
Mensagem por rodrigofelippe »
preço: 3.700
HPI Racing - Cars - Baja 5B RTR HPI's new giant Baja 5B buggy will take RC Cars to a new dimension!
The Baja 5B is a 1/5th scale off-road buggy that is nearly 32" in length! Its design is revolutionary for large scale RC Cars following the style of classic Baja buggies with long suspension arms for great ground clearance and large suspension travel. The big size allows the Baja 5B to go where smaller buggies can't and makes the Baja 5B's driving experience as close as you can get to the real thing.
The Baja 5B is big, but coming as a "Ready To Run" car, and powered by standard gasoline it can't be easier to get ready for action. Everything is included in the kit - a preassembled Baja 5B chassis with high quality FM radio gear and a preinstalled massive 23cc gasoline engine providing plenty of power. All you need to do is fill up with standard gasoline and some oil, and off you go!
The innovative design of the Baja 5B has been developed and tested by HPI's designers over the last 18 months.
FEATURES: Chassis: Narrow channel monocoque design 0.16" (4mm) thick, purple in color constructed of aircraft grade 6061 T6 aluminum Drive: Rear wheel gear drive Engine: 1.40 cu in (23cc) gasoline with pull starter, dual element foam air filter, primer choke and kill switch Exhaust: Routed to rear of vehicle with pipe Fuel Tank: Radio: TF-10 FM receiver has adjustable failsafe, 6V 2000mAh rechargeable receiver pack, AC charger water resistant housing on chassis with external charging jack and rubber cap for easy crystal changes Servos: Water resistant with high torque 25kg-cm steering servo Clutch: Automatic centrifugal type Transmission: Ball Bearings: Full set included Shocks: Four Hyper Adjust Piston aluminum shocks with 5 externally adjustable dampening settings and dual rate springs for progressive dampening action on all surfaces Main Gear: tooth Gearbox: Front and rear sealed Differentials: Viscous Torque Control can be tuned using different weight diff oils, hardened metal planetary gears Brakes: Ventilated dual disc Tires: HPI Dirt Buster with different tread pattern for front and rear Wheels: Nylon 3-piece bead lock, bead is bolted to wheel to hold tire securely in place-no need for tire glue Body: Pre-painted buggy type with rear wing Roll Cage: Baja style high impact nylon protects engine and body from crash damage Bumpers: Suspension: Fully adjustable, long travel double wishbone Caster: Adjustable, with shim 22 / 25.5* stock / 29 degrees caster/toe-in refers to the angle of the front suspension when viewed from the side of the car in relation to the chassis Camber: Adjustable, camber refers to the angle of the tops of the tires from vertical when viewed from front or behind vehicle
contatos msn: ranuff@hotmail.com
Victor.Menezio
Re: [VENDO] HPI 1/5 Baja 5B Buggy RTR
Mensagem por Victor.Menezio »
Tem interesse em trocas?
Dê uma olhada:
http://www.rcmasters.com.br//viewtopic.php?t=19861
Obrigado.
Victor.Menezio
Dê uma olhada:
Obrigado.
rodrigofelippe
Victor.Menezio escreveu:Tem interesse em trocas?
Dê uma olhada:
Obrigado.
cara, no momento nao, so venda mesmo!
:D
rodrigofelippe
ABAIXEI O PREÇO
3.000 AGORA
FRETE MEIO A MEIO.
17KG
CEP 58030-000
automodelo2008
Registrado em: 28 Fev 2009, 21:00
Mensagem por automodelo2008 »
eu pago 3000,00 nele sedex a cobrar .
automodelo2008
se quiser tenho umas mil indicaçoes no ML .
rodrigofelippe
automodelo2008 escreveu:eu pago 3000,00 nele sedex a cobrar .
ja conversamos no msn...
amvjunior
Registrado em: 21 Set 2007, 22:00
Mensagem por amvjunior »
conforme acertado por msn
Voltar para “FR - Carros Off Road”
