novos codigos...ferramentas em geral...contando apartir da postagem no forum
http://www.hobbyking.com/buddy.asp?code ... 8157EF00BD
http://www.hobbyking.com/buddy.asp?code ... 0112CE0BD9
http://www.hobbyking.com/buddy.asp?code ... 2329766FDF
http://www.hobbyking.com/buddy.asp?code ... CCBE677BD6
http://www.hobbyking.com/buddy.asp?code ... BE954AFC1F
http://www.hobbyking.com/buddy.asp?code ... BC71066781
http://www.hobbyking.com/buddy.asp?code ... 64FC301C81
http://www.hobbyking.com/buddy.asp?code ... CDEE7D6B4D
http://www.hobbyking.com/buddy.asp?code ... E2704938BF
http://www.hobbyking.com/buddy.asp?code ... 83177F8A29
Links de DESCONTO da HOBBYKING (BuddyCode)
Re: Links de DESCONTO da HOBBYKING (BuddyCode)
DIA LINDO....SOL PLENO....E A POEIRA COMENDO SOLTA....EEEE POEIRÃOOOOOOOO
Códigos para hoje.. Tem bateria 3S de 5000mAh 30C com desconto..
ZIPPY Flightmax 5000mAh 3S1P 30C
http://www.hobbyking.com/buddy.asp?code ... 13666A3B63
Hobby King 30A ESC 3A UBEC
http://www.hobbyking.com/buddy.asp?code ... 08EC439E2F
Turnigy Hex Driver set 1.5~ 3.0
http://www.hobbyking.com/buddy.asp?code ... 6761DE3639
Blind Nut M2 size (10pcs)
http://www.hobbyking.com/buddy.asp?code ... 6A5A89D60E
Aluminum Spacers 7x5mm (10pcs/bag) - A2030, A2031 and A2033
http://www.hobbyking.com/buddy.asp?code ... F712B5067A
M4x4 Grub Screw (10Pc/Bag) - A2016T
http://www.hobbyking.com/buddy.asp?code ... 9C093F7572
- mach
Dremel HK de 14.79 por 12.28
http://www.hobbyking.com/buddy.asp?code ... 5F5AD28B58
Parafusadeira Elétrica de 4.99 por 3.63
http://www.hobbyking.com/buddy.asp?code ... D6D999367F
Se alguém quiser desconto para algo específico só pedir
Baterias e conectores no Armazem Europeu:
ZIPPY Flightmax 5000mAh 4S1P 30C (EU warehouse) de $39 para $34
http://www.hobbyking.com/buddy.asp?code ... BCFA1BE1EC
Polymax 5.5mm Gold Connectors 10 pairs (20pc) (EU warehouse) de $5,72 para $5,36
http://www.hobbyking.com/buddy.asp?code ... 54A65BE012
4mm Gold Connectors 10 pairs (20pc) (EU warehouse) de $2,89 para $2,45
http://www.hobbyking.com/buddy.asp?code ... 5A31E08D92
- zumpano
- Registrado em: 14 Abr 2013, 22:00
Como se usam esse código? Pq clico no link o valor está normal
Precisa estar logado na HK..
