Novo no automodelismo e preciso de ajuda ;D
Enviado: 12 Dez 2008, 22:25
Bom galera..é o seguinte... num entendo mer** nenhuma e pretendo aprende alguma coisa xP
Comprei um automodelo com as seguintes configurações:
Smartech 1:10 2-Speed 4WD Nitro Gas On-Road Model 10145
# Powerful 15CXP engine equipped with slide carburetor and pull-starter
# Disc brake system.
# Oil-filled dampers.
# 4-Wheel drive system with shaft drive.
# 2-Speed transmission.
# Original muffler and air filter.
# Solid and sturdy 2mm aluminum chassis.
# Built-in differential bevel gears (front and rear).
# A free electric starter included.
# Strong aluminum upper plate and chassis (2mm).
# High impact wheel.
# Front universal joint shaft.
# 80cc fuel pressure tank with primer pump.
# No-flex chassis design for better performance.
# High traction tires.
# Servo saver linkage system.
# Double wishbone suspension with adjustable width.
* 1:10 Speedy Tiger Buggy (100% assembled)
* 2 Channel Multifunctional Radio Transmitter
* English Manual
* Length: 380mm (15")
* Width: 200mm (7.8")
* Height: 320mm (12.6")
* Wheelbase: 260mm (10.2")
* Thread (F/R): 192mm (7.6")
* Gear Rate: (H)5.78:1, (L)8.24:1
* Engine: 15cxp
* Wheel Diameter: 66*26mm
* Radio: 2 Channel 27MHZ
* Weight: 1600g/3.5 lbs
Bom...tá tudo em inglês porque eu comprei no esterior e paguei cerca de 200 dolares...
Bom..como sou iniciante Gostaria de saber se fiz um bom negocio e se esse carrinho é bom xP
Agradeço desde já!
* English Manual
* Engine: 15cxp
Agradeço desde já!
