Tacon Soar Buggy RC Brushless RTR 1/14
Enviado: 08 Jun 2013, 10:23
Achei o bichinho até q bem construído...
http://www.nitrorcx.com/25c102-14-soar- ... hless.html
Features:
1. Tacon design treaded tires
2. Tacon design slipper pad with adjustable gear cover
3. Aluminum-threaded, oil-filled, coil-over, 6061-T6 ajustable shocks
4. 2.5mm 6061-T6 aluminum shock towers
5. Front and rear metal gear differentials
6. Brushless Tacon ESC
7. 2838 4500KV brushless motor
8. 4WD shaft drivetrain
9. Adjustable mini servo with saver
10. Steel hinge-pins with rounded front bumper
11. Tacon receiver with 2.4GHz technology
12. 7.2V 1100mAh NiMH battery with 3.5mm gilded round connectors
13. 2.5mm anodized aluminum rear and front kick-up chassis with dirt guards
14. 12mm wheel hexes
Specifications:
Scale: 1/14 Tacon Soar Buggy
Length: 304mm (12in)
Width: 202mm (8in)
Height: 110mm (4.3in)
Wheelbase: 186mm (7.3in)
Weight: 0.90kg (1.9lbs with battery)
Tire Type: Tacon Buggy
Chassis: 2.0mm anodized aluminum
Motor or Engine: 4500Kv 2838 brushless motor
Gear ratio: 8.23
Speed Control: Brushless
Radio: 2.4GHz Technology
Batteries: 7.2V NiMH with 3.5mm gilded round connector, Charger included
Shock Type: Aluminum-threaded, oil-filled, coil-over
Ball Bearings:Complete
Features:
Specifications:
Width: 202mm (8in)
Gear ratio: 8.23
