[NOVO] ESC Tekin RX8 GEN2
RX8 GEN2 1/8th Scale Competition Brushless Controller
http://www.teamtekin.com/rx8.html
Recursos:
Ultra-smooth and Precise Throttle and Braking Control
Compatible with Sensored/Sensorless Brushless and Brushed Motors
Easily Access Programming, Anywhere, Anytime
Datalogging Capability
High Voltage Programmable BEC
EZ Access HotWire Programming Port
HotWire PC Interface for Advanced Programming and Updating
D2: Dual Drive Mode Technology
On-Board Temperature Indicator
Removable/Replaceable Cooling Fan
HDAC: High Density Copper PCB's
Sensor Plug for Precise Commutation with all Motors
Gold-plated Solder Posts for Easy Wire Replacement
Self Test Diagnostics and Factory Reset
Pit Tune Mode
DGF2: Digital Glitch Filtering V2
QuickTune™ Programming
One-Touch Radio Calibration
30mm RX8 Fan Included #TT3832
High airflow volume for extreme cooling
Impact resistant durable design for offroad applications
Brushless Motor
Recursos Programáveis
High Voltage BEC (6.0v/7.4v)*
Drag Brake (13 steps)
Brake / Reverse Strength (13 steps)
Current Limiter (none + 12 steps)
Neutral Width (13 steps)
Timing Profiles (5 preset - 2 custom*)
Adjustable Throttle and Brake Minimums
Custom Throttle Curves
Motor/Reverse Type: Brushless, Brushed, No Rev, Rev Delay
Voltage Cutoffs (none, 2S, 3S, 4S, 5S, 6S, Custom)
Save, Load and Share custom ESC setup files*
Save, Load and Share Data Log files*
Extensive Tuning via Tekin HotWire PC Interface
Especificações
Controls: Forward/Brake/Reverse
Input Voltage: 2S-6S Lipo
Continuous Current: 220 Amps*
BEC: 6.0v / 7.4v 7amps
Motor Limit Brushless Mode: No Limit
Motor Limit Brushed Fwd Only Mode: No Limit
Motor Limit Brushed Fwd/Rev Mode: No Limit
Max Current: 220amps per phase
Timing Profiles: 7 choices (on board)
Brushed Modes: Fwd Only, Fwd/Rev, Rev Delay
Brushless Modes: Fwd Only, Fwd/Rev, Rev Delay
Dimensions: 1.5 x 2.2 x 1.4in (38 x 55.8 x 25.5mm)
Weight: 2.7oz / 76.5g
Tekin recommends LiPo batteries with at least a 40C discharge rate for 1:8 applications.
*Requires HotWire Sold Separately
Rusty98
Registrado em: 26 Fev 2013, 21:00
Re: [NOVO] ESC Tekin RX8 GEN2
Mensagem por Rusty98 »
Tá parecendo o mesmo esc que o anterior. Devem ter só mudado o software. A princípio, vejo que ele puxa 220A e o anterior 210A. O sensor de temperatura, como será a leitura dele? waterproof?
Rustler 1998 - Ofna LX2e
RC Imports no Facebook
Cris_LB
Registrado em: 03 Mai 2012, 22:00
Mensagem por Cris_LB »
Eu tenho um desses...
A leitura do sensor de temp. é feita por alguns Leds que tem no próprio ESC...
A outra diferença é que vc pode selecionar BEC de 6v ou 7,4v.
E não é waterproof...
Rmartins
Mensagem por Rmartins »
Ou seja quase nenhuma diferença perceptível
Estes dois achei interessante:
