KIT Team Losi 8ight 2.0 Truggy
Preço: 1.550
FRETE INCLUSO
Boasting user-friendly, track-tested tuning setups from top Losi racers the 1/8-scale nitro powered 8IGHT-T 2.0 Truggy Race Roller is professionally dialed and assembled in a race-ready configuration. The 8IGHT-T 2.0 builds upon the innovation of its predecessor by offering 37 newly engineered features and design elements.
The 8IGHT-T 2.0 Race Roller is built on an extended-length Tuned Flex Technology (TFT) 2.0 chassis (14mm longer) which offers added stability and handling across all track conditions. This increased stability gives the 8IGHT-T 2.0 Race Roller the ability to carry more speed into and out of corners, and to glide across washboard sections with ease. Tuned Flex Technology also provides significant handling gains by responding precisely to changes in terrain without sacrificing balance and grip.
The 8IGHT-T 2.0 Race Roller includes updated steering geometry which features a servo saver with increased consistency. Additional gains in steering precision were made by incorporating a pressed-steel bushing in the Ackerman brace, which reduces friction over the entire range of motion. With the increased horsepower demands of 1/8-scale truggy racing, Team Losi Racing reengineered the dogbones and outdrives of the 8IGHT-T 2.0 Race Roller to stand up to the abuse associated with serious off-road competition.
For balanced braking, Team Losi Racing designed 30mm front and 33mm rear heavy-duty brake discs that greatly improve brake feel and cooling. The heavy-duty design and construction ensures that you can accelerate further into corners before having to brake, allowing for faster lap times and quicker exits from the corner.
The alloy shock towers on the 8IGHT-T 2.0 Race Roller have been strengthened and lightened for better on-track performance without sacrificing handling or strength. The suspension on the 8IGHT-T 2.0 Race Roller features numerous shock mounting locations for several options in adjusting the suspension setup. The front carrier also features two camber link positions while the rear has four, allowing for even greater customization to varying track conditions. The updated suspension includes the use of 15mm longer front shocks and 20mm longer rear shocks, extending the amount of suspension travel for increased handling capabilities on even the roughest of tracks.
Utilizing results from worldwide competitions, the 8IGHT-T 2.0 Race Roller includes a 50T center spur gear designed to provide the perfect gear ratio for truggy racing. Combined with the numerous advancements and updates to the vehicle overall, the result is an even more dominant performance on any track and in any condition.
A revised radio tray on the 8IGHT-T 2.0 Race Roller optimizes the position of the servos, while increasing response time and reducing stress on the throttle servo. This design also allows for increased precision from the throttle servo while reducing weight. The sure-close fuel tank ensures automatic, positive closure and prevents air from entering the fuel system.
All suspension arms on the 8IGHT-T 2.0 Race Roller have been extended a full 15mm for a wider, more stable base that maintains outstanding handling over any terrain. The extended width also allows for more stable entry into and exit from the corners, cutting valuable seconds off your lap times. Zero-Offset wheels were designed to keep the overall width within race guidelines while still offering incredible handling improvement. The 8IGHT-T 2.0 Race Roller also features an updated body design that increases air flow to the engine cooling head for improved engine performance.
Features
Extended Chassis with Tuned Flex Technology (TFT) 2.0
Precision steering geometry and servo saver
Extended-length front and rear arms
Updated suspension geometry with longer front and rear shocks
Heavy-duty dogbones and outdrives
Heavy-duty front and rear brake disks
Lightened shock towers
Sure-Close™ fuel tank closure with EFRA approved fuel line kit included
50T Center spur gear
Revised radio tray design
Heavy-duty rear outer 3.5mm hinge pins
Reinforced rear bearing insert system
Laser etched engine mounting guides
Center driveshaft grease boots
Specifications
Type: 8IGHT-T 2.0 Truggy Race Roller
Scale: 1/8
Length: 22.075 inches (560mm)
Width: 16.375 inches (415.9mm)
Wheelbase: 14.93 - 15.09 inches (379 - 383mm)
Weight: 8.50 lbs. (3.855kg)
Chassis: Tuned Flex Technology (TFT) 2.0
Kit/RTR: Race Roller
Body: Clear Polycarbonate Body
Needed to Complete
.21 or .28 Engine
Tuned Exhaust System
2-Channel Radio System w/High Torque Servos
Receiver Pack and Charger
Glow Driver
Starter Box
Nitro Fuel
Fuel Gun or Bottle
Paint for Polycarbonate Bodies
referencia: http://rc-mushroom.com/product_info.php?cPath=35&products_id=16412
contato:
MSN - ranuff@hotmail.com
Team Losi 8ight 2.0 Truggy - R$ 1.550 - frete incluso - NOVO
- rodrigofelippe
ReyBarroco
- Registrado em: 11 Jun 2008, 22:00
- rodrigofelippe
Re: Team Losi 8ight 2.0 Truggy - R$ 1.550 - frete incluso - NOVO
ReyBarroco escreveu:mp enviada
MP respondida, qualquer cisa so ligar 83 88803162
- Mineiro
vc troca por um Kit losi 1.0 Usado Race Roler... mas em ótimas condições???
tem um kit buggy race rolar também !!!
Patrocinadores:
RedeHobbyBrasil.com.br
ByMarcoAmaral.com.br
HobbyOne.com.br
DinizEsteves.com.br
Ultimate Racing
Ultimate Engines
Procircuit Tires
Odonnell Fuel
HobbyOne.com.br
DinizEsteves.com.br
Ultimate Racing
Ultimate Engines
Procircuit Tires
Odonnell Fuel
- caddu81
- Registrado em: 10 Jan 2009, 21:00
Conforme informado via MP, DOC enviado.
Abraços,
Caddu!
Abraços,
Caddu!
Caddu!
