Estou dando uma parada com o automodelismo e vendendo tudo para não deixar estragando.
Mugen MBX-6 com:
MUGE0242 Mugen Aluminum F/R Axle Shaft (4)
MUGE0185 Mugen Aluminum Rear Arm Mount
MUGE0243 Mugen Aluminum Joint Cup (2)
MUGE0177 Mugen Aluminum Front Upper Arm Bracket
MUGE0831 Mugen Titanium Upper Screw Set
MUGE0832 Mugen Titanium Lower Screw Set
MUGE0244 Mugen Conical Gear (42T) (Used w/E0245)
MUGE0245 Mugen Bevel Gear (12T) (Used w/E0244)
MUGE0173 Mugen Aluminum Rear Hub Carriers (2)
MUGE0558 Mugen Front Damper Spring (XXX Soft, 75mm, 10.25T) (2)
MUGE0561 Mugen Rear Damper Spring (XXX Soft, 86mm, 11.25T) (2)
Barras estabilizadoras: 3.0 Front e 3.2 Rear
Motor Ninja JX21B01A
Pipa Ninja JX21
Curva Ninja C-type
RB Gas Cooler
2 Servos Team Orion VDS 2015
Braços de alumínio (direção e acelerador/freio)
2 Bolhas Pintadas (Proline Shift e Proline Bulldog) muito novas, sem qualquer trinca.
Rádio Futaba 3PKS
Módulo/Receptor Spektrum 2.4GHz
Módulo/Receptor 72MHz Futaba
Case Alumínio
Vários Jogos de Pneus Usados, muito novos.
Jogo de Pneu Proline Crime Fighter M3 NOVO
Jogo de Pneu Proline HoleShot M3 NOVO
PEÇAS NOVAS:
e0601 MUGEN BEARING (15X21X4) e0601
e0149 MUGEN FRONT LOWER ARM e0149
e0148 MUGEN FRONT UPPER ARM e0148
e0150 MUGEN REAR LOWER ARM e0150
c0230 Mugen MBX5 diff.gear 10T (4pcs.) c0230
e0557 MUGEN DAMPER BOOTS e0557
e0411 MUGEN WING STAY e0411
e0811-b Mugen MBX5-R Rear upper arm link e0811-b
Mugen MBX6 UPDATED KIT Side Chassis Guards Bumper NEW
Mugen MBX6 UPDATED KIT Radio Box & Graphite Servo Tray
Mugen MBX6 UPDATED KIT White Rear Wing NEW
Mugen MBX6 UPDATED KIT F/R Big Bore Black Springs NEW (X SOFT)
Mugen MBX6 UPDATED KIT Linkage Rods and Parts NEW
Mugen MBX6 UPDATED KIT Diff & Shock Fluids Grease NEW
Mugen MBX6 UPDATED KIT (14) 8x16 (4) 15x21 Bearings
MUGEN MBX6 M-SPEC Flywheel,Aluminum Shoes,Springs MBX-6
MUGEN MBX6 M-SPEC Front Uprights and Pivot Balls MBX-6
MUGEN MBX6 M-SPEC Wing Mount Set MBX-6 MSPEC
MUGEN MBX6 M-SPEC Complete set Bearings MBX-6 MSPEC
MUGEN MBX6 M-SPEC Captured Suspension Pins MBX-6 M-SPEC
MUGEN MBX6 M-SPEC Air Filter Assembly MBX-6 MSPEC
MUGEN MBX6 M-SPEC Big Bore Front Shocks W/SPRINGS (XX SOFT) MBX-6
MUGEN MBX6 M-SPEC Big Bore Rear Shocks W/SPRINGS (XX SOFT) MBX-6
MUGEN MBX6 M-SPEC Body,Masks,Wing,Decal MBX-6 MSPEC
MUGEN MBX6 M-SPEC Rear Upper Rods MBX-6 MSPEC
MUGEN MBX6 M-SPEC Sway Bar Kit MBX-6 MSPEC (2.3 e 2.
MUGEN MBX6 M-SPEC Steering Turnbuckle / Tie Rods MBX-6
Caixa de partida NOVA:
HUDY Hudy Star-Box Truggy & Off-Road 1/8 104500
2x Bateria LiPo 2S - 5.000mAh
2x Medidor de bateria LiPo
Alarme para bateria LiPo 4S (avisa quando a bateria está descarregada na caixa de partida)
Para ficar claro, o carro foi montado para o Henrique Winik correr o Brasileiro 2010, correu o campeonato e acabei comprando quando terminou. Após isso, andei uma vez (40 minutos). O carro está limpo e revisado.
Não tenho interesse em vender nada separado.
O valor do pacote completo: R$ 6.000,00
A pessoa pode se assustar com o valor, mas pode ter certeza que vale isso tudo e muito mais. O carro está completo, com muitas peças reserva. Basta o comprador colocar combustível e comprar um hot-shot para ligar o carro.
A caixa de partida da Hudy está lacrada ainda, não foi usada, bem como as baterias. É uma das melhores caixas que já tive, essa é a terceira que compro (as outras duas já vendi para colegas).
