Já li algumas opiniões boas sobre este modelo...
Eu vou investir uma grana no hobby e para isso preciso acertar. Meu primeiro auto foi um genérico - do paraguai - mas que não vai aguentar muito. Eu ia fazer um up-grade nele mas estou na dúvida entre:
Um rádio futaba 3PM
Dois Servos S3151
Motor HPI Nitro Star .15 Pull Starter
OU
HPI Nitro RS4 3 EVO+ RTR w/1966 Mustang GT Body
FEATURES: Chassis: 0.098" (2.5mm) 6061 aluminum, purple in color
Drive: Four wheel shaft drive
Engine: Nitro Star G3.0 3.0cc (.18 cu in) 2.2hp with pull-starter,
can be bump started in racing applications) ABC cylinder and liner
construction-"A"luminum piston,"B"rass cylinder liner that is
"C"hrome plated, lightweight aluminum con rod, 2 needle 6.5mm
rotary carburetor, 2 stage air filter, HPI Roto-Start electric
starter
Exhaust: Dual chamber aluminum tuned pipe with tube header, black in
color
Radio: Two channel 27MHz AM with steering and throttle trims, dual
rate for steering and charge jack for optional NiCd battery
Servos: Two standard size and torque
Fuel Tank: 2.53oz (75cc), flip top cap
Clutch: 2-shoe
Transmission: Two-speed, adjustable
Ball Bearings: 18 rubber sealed
Shocks: Four oil-filled, with coil-over spring
Main Gear: 47 and 43 tooth composite construction main gears
Clutch bell: 22 teeth and 18 teeth gears that thread onto clutch bell
Gearbox: Sealed, front and rear
Differentials: Sealed, with metal bevel gears, limited slip front
differential
Brakes: Single disc, fiber construction
Tires: D compound X-pattern 1.02" (26mm) wide, 2.5" (65mm) diameter
Wheels: Vintage 5-spoke matte finish chrome
Body: Pre-painted and trimmed with rear wing and decals applied
Bumper: Front foam
Suspension: Four wheel independent
Caster: Adjustable, caster/toe-in refers to the angle of the front
suspension when viewed from the side of the car in relation to the
chassis
Camber: Adjustable, camber refers to the angle of the tops of the
tires from vertical when viewed from front or behind vehicle
Steering: Bellcrank
Servo Saver: Included
O carrinho sai U$100,00 mais caro que as peças...
O que vocês acham??
PS.: pode parecer óbvio, mas nunca é demais conversar com quem é do ramo...
URGENTE!!
- Pries_jeden_Got
Re: URGENTE!!
Pega o carro... ou o rádio caso queira pegar logo um carro melhor... tipow um pro... o chassi vc nunca mais ganha a grana q invistirá... já o rádio não desvaloriza tanto assim... eu aprendi uma coisa... se queis um carro bom o sistema de rádio tem ser bom tb... o 3pm é um excelente rádio mas eu pegaria já um 2.4Ghz... os servos ai s3151 são muito fracos... compra dois s3305...
