Features
•Big Bore Shocks - Equipped with large capacity oil shocks as standard. Soaks up bumps with ease and secures smooth jump landings. Features dial adjustable chassis height setting.
•Finished Body - Pre-cut body features sharp 6-color printed color scheme. Combines with the aerodynamic curved surfaces of the large wing to generate strong down-force.
•Multipoint Adjustments - Design features multi-point setting adjustments such as chassis height, camber, tread, front and rear toe-in etc.
•Aggressive Tires - Pin-spike tires with inner sponge supports are fixed to wheels with on 5mm axles with aluminum wheel nuts. Compatible with tires sold in the general market.
•Shaft Drive - The drive shafts run through the center for chassis to give you better lower CG and optimum weight balance.
•Fully Digital Servo - Equipped with a digital servo for great response.
•Wide Stance - Long span suspension arms create the wide tread on the double wishbone 4-wheel independent suspension system for superior running stability.
•Fully Interchangeable - Front / rear and left / right suspension arms, front / rear knuckles and front / rear shock stays are all interchangeable. Newly designed suspension with maintenance-friendly ball connect system.
•Compatible with DBX/DST - The DBX VE is 60% compatible parts wise to its nitro version, so parts availability is not an issue.
•New Steering Layout - The DBX VE has a whole new steering layout witch gives you greater response and much more of a steering angle than the DBX gp version .
•Aluminum Motor Mount - Equipped with a black aluminum motor mount to secure the 540 Size Orion BL motor.
•Steel Pinion Gear - The DBX VE is equipped with a strong machine steel pinion gear for added security and durability.
Team Orion Experience BL Motor:
•540 Size Motor
•3720 KV
•Accepts 6-7 cell NiMh Battery or 2-3S Lipo Battery
•Max RPM (N/A)
•Sensorless
•Built in Cooling Fins
Team Orion Experience ESC:
•Sensorless Brushless Only*
•Accepts 6-7 cell NiMh 2-3S Lipo
•BEC Voltage 6V
•BEC Amp 2A
•Low Voltage Cut-off Auto Detect 3.0V/cell
•Thermal Protection at 95c
•Forward/ Brake/ Reverse or Forward only
•Continuous Max Current 70A
•Peak Current 150A
Contents:
•Pre-Assembled Chassis
•Pre-Painted Body
•Team Orion Experience B/L Motor
•Team Orion Experience ESC (Sensorless Only)
•Perfex KT6 Transmitter and R/C System
•L Hex Wrench
•Cross Wrench
Required For Operation:
•AA- Batteries x8
•7.2NiMh Stick Pack (3300mAh or higher) w dean plugs
•2S- 1P Lipo with deans plugs
•3S- 1P Lipo with deans plugs
•Proper charger for proper type of battery
