Some of the parts will be available in the US. They are:
LOSA5422 15mm Shock Cap Top, Vented
LOSA5431 Foam Compensator for vented shock caps
LOSA1728 Aluminum Inclined King Pin Spindle & 12 deg Carrier
LOSA1729 Aluminum Inclined King Pin Spindle
LOSA1733 Aluminum Inclined King Pin Spindle Carrier, 12 deg
LOSA1734 Aluminum Inclined King Pin Spindle Carrier, 10 deg
LOSA99040 Metal Servo Arm Insert, 23S Airtronics
LOSA99041 Meatl Servo Arm Insert, 23 JR
LOSA99042 Metal Servo Arm Insert, 24 Hitec
LOSA99043 Metal Servo Arm Insert, 25 Futaba
LOSA3551 Cente Diff 46T Spur Gear
The following parts will ONLY be available in Europe, South Africa, UK, and Australia
LOSA1713 Front Tower
LOSA1719 Rear Tower
LOSA9169 Tuned Pipe Mount (only difference is it is HA black)
LOSA8093 8IGHT 2.0EU Body
LOSA3539 Wheel Hex (only difference is they are HA black)
LOSA1757 Adj Front Hinge Pin Brace w/inserts-(only difference it they are HA black)
LOSA1758 Adj Rear Hinge Pin Brace w/inserts-(only difference it they are HA black)
LOSA8382 8IGHT 2.0 EU Logo Sticker Sheet
LOSA8383 Team Losi Racing Sticker Sheet: 8 2.0EU.
http://www.losi.com/Products/Default.as ... LOSK0804EU
