Bom pessoal, comprei este chassis da revinho no ebay, e ai fui montando ela com peças e upgrades que achei necessários.
Seguem as fotos:
CHASSIS E – REVO 1/16:
ACESSÓRIOS PARA A SUSPENSÃO:
Aluminum Toe Links Red - TRA 7138X
Aluminum Pushrod Red - TRA 7118X
RPM Front Upper/Lower A-Arms Red - RPM 80699
RPM Rear Upper/Lower A-Arms Red - RPM 80609
Aluminum Wheelie Skid Bar - VXS133E01
ACESSÓRIOS TRANSMISSÃO:
Integy Center Drive Shaft - T3409
Integy Universal Drive Shafts - T3432
50t steel spur gear - SVXS850
MOTOR / MONTANTE / ESC / OUTROS:
EZ-RUN Brushless Motor 9T 4300Kv - 3650-9T
Big Block Motor Mount - Tenbol 1000
Turnigy Brushless ESC 60A w/ Reverse - 60A-SL (o escolhido foi o 60A, mas por enquanto estou com o 35A)
TRAXXAS 2423 PINION GEAR 23T
XT60 Harness for 2 Packs in Parallelo
RODAS / PNEUS / BOLHA / HEX HUB:
HPI Racing SS Monster Wheel - HPI 2105 SS
Pro-Line Road Hawg II 2.2" Street Truck Tires
Revo Chrome Rim and Tire Set - TOYZ201
ProGraphix Body - TRA7111X
Aluminum wheel hubs - VXS10W06
QUASE PRONTO, FALTA POUCO PARA ANDAR:
ITENS COMPRADOS QUE AINDA NÃO CHEGARAM:
Nuts 4mm Flanged Nylon Locking - TRA 1747R
Turnigy Speed Controller Programming Card - TG-Prog
TGY-390DMH High Performance MG Digital Servo - TGY-390DMH
ZIPPY Flightmax 1800mAh 2S1P 20C - Z18002S20C
Rhino 1750mAh 3S1P 20C Lipoly Pack - R1750-20-3
E AI O QUE QUE ACHARAM ? O QUE POSSO AINDA MELHORAR ?
