Vendo OS 21XZ-B Speed (Zero - novo na caixa)
Motores, Peças de Motores, Carburadores, Pipas para Off Road
gilson.beckman
Registrado em: 10 Mar 2008, 21:00
Mensagem por gilson.beckman »
Vendo OS SPEED .21 XZB XZ-B (PRETO) NA CAIXA
R$1.050,00
- Procedencia: EUA - Towerhobbies
- Comprado em Jun/11
O.S. Speed 21XZ-B V-Spec Tuned Off-Road Competition Buggy Engine
[OSM12186]
Features:
Race-Winning Power Characteristics: A tried and true 3-port sleeve design (3 bypass ports, 1 exhaust), provides smooth, crisp acceleration. This has been achieved through a combination of a specially designed "SPEED" inner head and sleeve porting. Fuel mileage has been improved by 8%*
Outer Head: The low-gravity, black-anodized outer head features laser engraving and has been heavily machined for improved cooling and extra weight reduction. The overall height is 9mm shorter than the previous model, providing a lower center of gravity and a greater level of stability.
Carburetor: A newly designed 21J2(B) carburetor includes 6, 6.5, and 7mm aluminum venturi's. Even the smallest 6mm venturi doesn’t affect its easy tuning characteristics.
Ceramic Ball Bearing: The black anodized crankcase adds a ceramic ball bearing in the rear to reduce rolling resistance.
Crankshaft: The crank intake passage is silicone ramped for a better fuel mixture flow. A tungsten insert is pressed in the counterweight to optimize inertia mass. DLC coating is applied to minimize frictional loss as well as improve durability and lifespan.
Includes:
T-P3 Glow Plug
Exhaust Gasket
18mm, 16mm & 3mm Dust Cap Set
6mm, 6.5mm & 7mm Carburetor Venturi's
Specifications:
Displacement: 3.49cc
Bore: 16.27mm
Stroke: 16.8mm
Practical RPM Range: 4,000 - 40,000 rpm
Output: 2.6ps @ 34,000 rpm
Weight: 355 grams (12.52oz)
compared to the 21VZ-B V-Spec II Speed
Gilson Beckman
LOSI 8ight 2.0 - OS - Spektrum
Re: Vendo OS 21XZ-B Speed (Zero - novo na caixa)
Recomendo!
kkkkk
rbergamo
Mensagem por rbergamo »
aceita troca? tenho uma revo zero Ediçao especial...revo platinum profissional
valeu e desculpa o incomodo ai
gilson.beckman
Rbergamo. Obrigado pela oferta mas não estou aceitando troca. So dinheiro mesmo.
Gilson Beckman
Kimo
Mensagem por Kimo »
Também recomendoooo.....eita motor !!!!!!
RPDS
Registrado em: 22 Nov 2010, 21:00
Mensagem por RPDS »
Gilson
Vc parcela no cheque?
RPDS
Mensagem por RPDS »
Gilson
fiego
Mensagem por fiego »
c fiz 1000 eu compro, esse é aquele modelo novo com o cabeçote menor???
fiego
atá vi a foto agora, tinha dado erro na foto, 1000 + sedex
gilson.beckman
RPDS escreveu:Gilson
RPDS, no cheque fica ruim para mim, posso anunciar no Mercado Livre e vc divide no cartao pelo mercado pago. Acho que o Mercado Pago aceita pagamento direto mesmo sem anuncio no ML, nao sei direito como funciona, mas se lhe interessar, eu descubro como funciona e fechamos.
Abracos.
Gilson Beckman
gilson.beckman
VENDIDO!
Gilson Beckman
fiego
so aceita a proposta hehehe
Voltar para “FR - Motores Off Road”
