Rádio HK GTX3
Rádio HK GTX3
Mais um lançamento de baixo custo da HK...
Mas está mais para um GT3B remodelado..
The much-anticipated and exclusive Turnigy GTX3 AFHDS 2.4ghz 3 Channel radio system is here! This great looking Transmitter uses proven channel hopping technology to provide a solid, reliable link for RC Cars & Boats.
The Turnigy GTX3 features a large Back-lit LCD, A quick access jog wheel for function selection and programming, 10 Model memory, Steering wheel extension as standard, a host of programming features and compatibility with the already proven HK-GT2R 3 Channel receiver. The GTX3 can also connect with the free to download VRC Race Simulator when used with the optional USB cable (not included, see related items below). The combination of great features and solid reliability means the Turnigy GTX3 could very well be the last radio you will ever need!
Specs:
Channels: 3
RF Type: 2.4Ghz AFHDS
Bandwidth: 500Hz
RF power: less than 20DB
Sensitivity: 1024
Low Voltage Warning: Yes (less than 9V)
Fail Safe: Yes
DSC Port: Yes (3.5mm PPM)
Charging Port: Yes
Power: 12V DC (1.5AA x 8)
Weight: 395g
CE & FCC certified
3.9" Blue Back-lit LCD
Programing Options:
Model Memory (10 Models)
Servos NOR/REV
Steering Trim
Throttle Trim
Dual Rate
End Point Adjustment
ABS Settings
EXP Settings
Includes:
Turnigy GTX3 Transmitter
Turnigy GTX3R 3 Channel receiver
RX Antenna Tube
Bind Plug
User Manual
http://www.hobbyking.com/hobbyking/stor ... ystem.html
Entrada para Simulador:
Agora dúvidas:
Binda com o RX GT2R?!
Será q arrumaram o volante?!
E o problema com o gatilho frágil?!
