[VENDO] Reds R7 Evoke Limited Edition engine
Motores, Peças de Motores, Carburadores, Pipas para Off Road
magris4
Registrado em: 18 Nov 2006, 21:00
Mensagem por magris4 »
Vendo Reds R7 Evoke, lacrado na caixa.
The new 7 ports completes REDS Off Road range since it has specific features studied for particular conditions. The REDS R7 Evoke is limited to 300 pieces worldwide.
7 ports main features:
Suitable for low grip tracks.
Suitable for winding and narrow tracks.
Specific torque for high driveability and smooth power delivery.
Low fuel consumption.
Innovative design, specifically chosen to distinguish the new engine
High-end engine.
R7 Evoke tech spec:
Sleeve with 7 inlet ports and exhaust port with boosters.
Silicon filled, balanced and tuned crankshaft.
New front high sealing bearing
Rear ceramic high quality bearing.
RDC hard coating back plate.
Long needle carburetor.
Available with 6.5 and 7 mm venturi.
All parts are matched, measured by Mario within certain tolerances, hand built by him personally.
The engine leaves our factory with a hand inspection of all components and compression is checked.
Recommended with 2112 pipe and S manifold.
Preço de venda: 1250
davidgirdan
Registrado em: 16 Jul 2009, 22:00
Re: [VENDO] Reds R7 Evoke Limited Edition engine
Mensagem por davidgirdan »
tem coo mandar fotos reais para david.silva777@gmail.com
magris4
enviado
Voltar para “FR - Motores Off Road”
