Ofereço à venda:
Rádio Sanwa/Airtronics MTS, com receptor RX-462 com telemetria.
Mais novo lançamento da Sanwa, rádio excelente!
Valor: R$949,00 + frete
Especificações do rádio (em inglês - a partir da página do fabricante: http://www.sanwa-denshi.com/rc/car/propo/mt-s.html):
●WHITE LED BACK LIGHT
●LARGE FULL-DOT LCD MONITOR(128x64dot)
●ST TH TENSION ADJUSTMENT
●ADJUSTABLE TRIGGER
●BUILT-IN ANTENNA
●TELEMETRY FUNCTION
●DUAL RATE
●SERVO SPEED
●SERVO REVERSE
●TRIM/SUB TRIM
●CURVE(EXPONENTIAL / ADJUSTABLE RATE CONTROL)
●FAIL SAFE(RADIO WAVES / BATTERY)
●EPA
●OFFSET
●BIND
●TH TYPE(70:30/50:50)
●ANTI-LOCK BRAKE
●MODEL NAME(10 LETTERS)
●MODEL MEMORY(20 MODELS)
●MODEL(SELECT/CLEAR/COPY)
●TIMER(LAP / INTERVAL / DOWN)
●LOGGER
●ALERT SETTING
●TELEMETRY SETTING
●KEY ASSIGN(SW / TRIM)
●BUZZER(SCALE / VOLUME CHANGEABLE)
●TRANSMITTER BATTERY ALARM
●LCD CONTRAST
●VOLUME ADJUSTMENT
●SETUP WIZARD
●RF MODE SETTING(FH4/FH3)
●RESPONSE MODE (NOR/SHR/SSR)
●DIRECT MODEL SELECT
●AUX1(SELECT THE OPERATION TYPE OF 3CH)
●AUX2(SELECT THE OPERATION TYPE OF 4CH)
●AUX TYPE SETTING
●CODE AUX (COMPATIBLE WITH SUPER VORTEX ZERO & TYPE-D MENU)
●STEP AUX (STEP 1 to 100)
●POINT AUX (2 to 6 POINT)
●4WS MIXING (FRONT/REAR/NORMAL/REVERSE
●MOA MIXING(FRONT-WHEEL-DRIVE/4WD/REAR-WHEEL-DRIVE) - DRIVE RATE IS VARIABLE.
●AUX MIXING (ST MIXING, TH MIXING)
●4 CELL DRY BATTERY
●COMPATIBLE RECEIVER: RX-380, RX-381, RX-451, RX-451R, RX-461, RX-462, RX-471, RX-472, RX-481, RX-482
O receptor RX-462 acompanha sensores de RPM e temperatura, e cabo de monitamento de bateria (apenas para bateria 2s).
Especificações do receptor (em inglês - a partir da página do fabricante: http://sanwa-denshi.com/rc/car/receiver/rx-462.html):
●Telemetry
●Battery voltage sensing terminal included
●2.4GHz FHSS4 Spread spectrum system 4ch
●Sanwa Super Response (SSR) support
●Frequency: 2.4GHz FHSS4
●Channel: 4ch
●Nominal Input Voltage: 4.8-7.4V
●Dimensions: 36.2 x 26.5 x 16.3mm
●Weight:10.8g
ATENÇÃO:
Apenas venda, sem trocas!
Frete por conta do comprador.
Reserva apenas mediante sinal (30% do valor).
