DuraTrax Piranha AC/DC Digital Peak Charger NiCd/NiMH
Ferramentas, Tendas, Caixas de Partida, Caixas de Campo, Termômetros, Mesas, etc
alexmattos
Registrado em: 18 Mai 2007, 22:00
Mensagem por alexmattos »
POUCO USO, PARECE ZERO!
QUERO: R$ 156,00 (60% DO VALOR DO NOVO, PREÇO JUSTO)
Fabricante:duratrax
Descrição do Produto:
This is the NEW Digital Peak Charger by Duratrax.
FEATURES: AC/DC convenience is great for use at home or at the track
Peak charges 1-8 NiCd or NiMH cells.
Peak charge current adjustable from 0.1 to 5 amps (3 amps with AC)
Two-line, 16-character LCD display for easy programming and data
display
Displays battery voltage, peak detection mV, charge time, current,
and capacity
Adjustable peak detection sensitivity or "threshold" from 3mV-20mV,
to custom match the charger to specific batteries
Automatic charge mode changes if specific setting are not pre-set
Selectable TRICKLE charge rates - 0, 100mA, 200mA
Displays errors for improper input voltage, poor battery connections,
and reverse polarity on the output
Store pre-set charge parameters in memory for 10 battery types
Multiple sound cues and melodies
Microprocessor controlled intelligence and reliability
Solid State reverse polarity and short circuit protection on
input and output
INCLUDES: One charger
One Battery Lead (Kyosho Connector)
One Instruction Packet
REQUIRES: Power Source
SPECS: Input Voltage: 110V AC 60Hz, 11-15V DC
Cell Types: NiCd and NiMH
Cell Count: 1-8
Peak Charge Rate: 0.1- 5.0 A (3.0 A with AC power source)
Charge rate increments: 0.1 A (100mA)
Fast charge termination: zero delta peak (3 - 20mV/Cell)
TRICKLE charge rates: 0, 100mA, 200mA Selectable
Output connectors: spring-loaded terminals
Case Size: 5"x3.4"x5.5" (127x86x140mm)
Weight: 2.94 lb (1335g)
____________
Alex Mattos
wagnerrs
Re: DuraTrax Piranha AC/DC Digital Peak Charger NiCd/NiMH
Mensagem por wagnerrs »
tem as especificações mas é mais facil perguntar
1) Pode ligar na bateria do carro 1/1 (12V)?
2) vem com o cabo para ligar na bateria do carro?
3) Da para carregar aquecedor de velas?
4) Da para carregar pack de 6V de PRO12? ja vem o plug (femea)?
5) Da para carregar Pack de Rádio (acho que é 9.6V)?
"T N T RACING"
Dicas e brindes de RC aqui
alexmattos
wagnerrs escreveu:tem as especificações mas é mais facil perguntar
SIM
SIM (2 JACARÉS, PRETO E VERMELHO)
SIM, POIS ELE FUNCIONA COM 1 CÉLULA SUB-C, E ESSE CARREGADOR CARREGA 1 SOZINHA TAMBÉM (PORÉM, NÃO SEI COMO FARIA A CONEXÃO. NUNCA USEI UM AQUECEDOR DESTES.)
SE ESTÁ FALANDO SOBRE A BATERIA DO RECEIVER, DE 5 CELULAS 2/3, EU MANDO O ADAPTADOR QUE EU FIZ PARA ISSO.
SIM, PQ ELE CARREGA ATÉ 8 CELULAS, QUE SÃO 9,6V (PORÉM, NÃO SEI COMO FARIA A CONEXÃO. NUNCA USEI UM PACK DESTES.)
OBS: ELE TEM DUAS ENTRADAS DE FIO COMUM FRONTAIS PRETO E VERM. (VEJA NA FOTO), PORTANTO PODE-SE FAZER QUALQUER ADAPTADOR PARA ELE (JÁ VAI COM O TAMYA E DO PACK DE RECEIVER).
OBS2: CARA, PARECE ZERO MESMO!. NINGUÉM DIZ QUE JÁ FOI USADO ALGUMA VEZ. TÁ IGUAL O DA FOTO. É UM ÓTIMO NEGÓCIO!, TODO DIGITAL, PODE GRAVAR AS CONFIGURAÇÕES PARA CADA TIPO DE PACK.
____________
Alex Mattos
MarcosCorreia
Registrado em: 09 Jul 2007, 22:00
Mensagem por MarcosCorreia »
nossa cara otimo carregador e num preço exelente, pena eu ter comprado o meu a pouco tempo e estar meio quebrado de grana agora..boas vendas
rcp_potenci
Mensagem por rcp_potenci »
Alex,
te mandei um e-mail...
vlws,
Rogério.
Voltar para “FR - Acessórios”
